servis m6002 repetitive 3 flashes on start/pause button
Home Forums Public Support Forums Help And Support Washing Machine Help Forum servis m6002 repetitive 3 flashes on start/pause button
  • #52368
    shed7
    have a servis m6002 that was dead ordered new board now have 3 repetitive flashes on the start/pause button , changed door lock but no difference
    all thoughts gladly appreciated
    #311523
    Washman
    Re: servis m6002 repetitive 3 flashes on start/pause button
    Was the board pre programed , if not it is waiting to be programed with the Janus programer device.
    Mike
    #311524
    shed7
    was led to believe was already programmed , but now you say that dunno , wher’d i go from here !!!!!!
    #311525
    timdowning
    If it was a NEW board it would be blank and the machine programmes itself when you first switch it on.
    If it was an OLD or RECON board it needs to be programmed to the code of the machine using the Janus kit.
    If you have the old board link the R1 resistor. This resistor goes open circuit and gives you the dead symptoms.
    #311526
    shed7
    yes still have the old board , and yes the machine was dead correct me if i’m wrong in what youre saying take the r1 resistor of the new board and put onto old board ?
    #311527
    timdowning
    Test r1 on the old board it should read the same as r2.
    If no circuit through r1 then I would just link across r1. Use a piece of wire soldered from one leg of r1 to the other leg of r1.
    Put the board back in machine and it should all be ok.
    Send the new board back and get your money back.
    I’ve by-passed r1 many times with no issues.
    #311528
    shed7
    indeed r1 resistor was blown , replaced and hey presto machine came to life and works as new , many thanks for all the help on this one guys
