Servis M6006-1W
  • #44063
    Jonah
    Can anyone help with the part number for the wash motor on this model, cant trust Connect as the module they list is incorrect for this model.
    Model number: M6006-1W
    Serial Number: 20071910433
    Module Part Number: 546089203 (taken from original module)
    Have fitted new module and will spin but no wash action, checked loom and all other usual suspects, could be new module faulty but dont think so as original module completely dead.
    #279657
    Washman
    Re: Servis M6006-1W
    Dead module 546089203 on these can be resister R1 its 47ohms 2 or 3watt . I have replaced quite a few of these resisters on 546089203 boards, also this board may need to be reprogrammed with the Janus code so you need the Janus programmer to do this .
    The Janus programmer will also show fault codes.
    Mike
    #279658
    Lawrence
    Re: Servis M6006-1W
    Washman wrote:Hi
    Mike
    I thought the top board programmed the bottom board ,Dave check your edge connectors they sometimes lose tension .
    #279659
    Jonah
    Re: Servis M6006-1W
    Thanks lads, I have checked edge connectors all ok, so if we fit a brand new PCB it needs to be programmed as well?
    #279660
    rogdodge
    Re: Servis M6006-1W
    Jonah wrote:Thanks lads, I have checked edge connectors all ok, so if we fit a brand new PCB it needs to be programmed as well?
    you do not need to programme module 546089203 if thats the part your fitting and if your interested I have this part in stock .
    #279661
    Jonah
    Re: Servis M6006-1W
    Hi Rog,
    I have already fitted a new module, I need the part number for the wash motor so I can check its one I have in stock or not, thanks for offer though 🙂
    #279662
    suedehead1
    Re: Servis M6006-1W
    the motor is 512020900 the number is normally printed on the motor
    #279663
    Washman
    Re: Servis M6006-1W
    Without the Janus hand held device you cannot fault find properly,it has the fault finding software,and reprogramming software which very often needs doing after a board change. Also to allow the top board to program the main board after switching on you need to leave it for at least 30 seconds to 1 min to finish the programing.
    Mike
