Re: Servis M6011 filter body
Had a couple of these where they have been leaking from the filter gasket and for some reason the they have put a stop on the filter that stops the user screwing it up to tight.
Also stops you screwing it up to stop the leak it the gasket compresses slightley – they don’t do gasket as spare or filter/filter housing but if you break/cut the stop off it allows you to tighten the filter properly. It is easy to miss as you aren’t looking for it (Who puts a stop on a filter!!! Some idiot obviously :rolls: )
Not sure this helps but might.
Mick
