Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › servis m6011 washer keeps taking on water and draining it st
- This topic has 12 replies, 4 voices, and was last updated 16 years ago by
Spishkey.
March 26, 2010 at 1:47 pm #53555
Spishkey
Participanti have a servis washing machine, its around 6 years old. never had a problem until recently.
now when i try to wash it keeps on taking in water, which flows into the washer and straight out the drain! the drum turns round once, then it starts taking on water again and lets it flow straight back out.
ive been told the fill valve may be broken? but i have no idea where this is situated on the machine? i bought the washer in the uk and moved to belgium, so finding a servis repairman here i think will be a challenge!does anyone know where i can get a manual or a diagram of whats what in the machine? how do i know what im looking for?
many thanksMarch 26, 2010 at 2:02 pm #316396Spishkey
ParticipantRe: servis m6011 washer keeps taking on water and draining i
sorry just read forum rules that you cant give diagrams, but can anyone tell me does it sound like a faulty/broken valve and ‘roughly’ where that piece would be?
March 26, 2010 at 3:00 pm #316397Spishkey
would holes through the grey door seal cause water filling problems?
March 26, 2010 at 3:10 pm #316398bazza500
Is your drainhose at the correct height?
March 26, 2010 at 3:12 pm #316399Spishkey
what height should it be??
i havent moved the hose height yet this problem has only just started……
March 26, 2010 at 3:17 pm #316400bazza500
Hold the drainhose in the sink and try the machine and see if that helps.
If it works then it is syphoning for some reason.
March 26, 2010 at 3:34 pm #316401Spishkey
its just doing exactly the same…filling and emptying….
March 26, 2010 at 6:06 pm #316402Penguin45
Is the pump running at the same time as it’s filling, or does it fill then pump?
March 27, 2010 at 5:59 pm #316403Spishkey
i would say at the same time, because as fast as the water goes in, it comes straight out the drain pipe outside….
March 27, 2010 at 6:24 pm #316404suedehead1
it sounds like the pcb is faulty plug out if checking.
but there will probably be nothing visible.March 27, 2010 at 8:39 pm #316405Penguin45
Yup, drain pump triac blown on pcb.
March 28, 2010 at 11:35 am #316406Spishkey
whats a pbc and can it easily be replaced? or is it better buying a new machine?
March 28, 2010 at 11:43 am #316407Penguin45
PCB – printed circuit board in the back of the machine. It is a notorious weak spot on Merloni/Servis appliances. There will be a number on the label starting 546——. This is the part number if you decide to replace the part.
