Servis m6115 fault
  • #53260
    borisdblade
    My service m6115 tripped the 32A mcb in my consumer unit about 5 mins into a wash cycle. After resetting the MCB, the machine failed to continue the cycle. The lights on the front of the machine are on but nothing is happening. I turned off the power and removed the top and back. There is no obvious burnt out wiring on the motor circuit and I can’t see and blown components on the control circuit PCB. Any help would be greatly appreciated.
    Thanks.
    #315153
    suedehead1
    Re: Servis m6115 fault
    the motor or heater will have damaged the main pcb, plug out of course.
    #315154
    If you’re certain that the pcb looks ok, the door lock may well be the culprit. 5 minutes in and the heater comes on – the load may be too much for the door lock to take. It’s switched by the timer/selector unit, not the pcb, which may be why it hs survived.
    Power off if you intend to investigate this for yourself.
