Servis M6115 – wash problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Servis M6115 – wash problem
  • #34269
    MickGeorge
    Hi Folks
    Went to this on Fri – Put on wash – when heater comes in – heats for about 3 mins on what looks like a staitionary heat then start button light goes out – carries on heating for aprox 1-2 mins then m/c shuts down.
    Suspect pcb fault athough had out and examined printed circuit which looks ok – on other tests notice occasional no motor action although spin ok – test for earth faults all ok and conventional stats fitted.
    Anyone come across this before or any pointers
    Mick
    #241917
    lerch
    Re: Servis M6115 – wash problem
    Usually is pcb but can be stats occasionally.
    #241918
    robbo1973
    i agree gen pcb on most servis if no motor action detected it skips to end.
    cheers chris.
    #241919
    MickGeorge
    Thanks for the replies folks… ordering a pcb
    Mick
    #241920
    MickGeorge
    Sorry for late update but thought I’d post the outcome.. changed module all working ok now..
    m/c didn’t have a stationary heat like I thought.. after changing module had drum action while heating. Obvious module fault if I had known that but because nothing standard anymore… well, you know the rest..
    Mick
