Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Servis M6135
- This topic has 13 replies, 8 voices, and was last updated 19 years, 4 months ago by
pmb.
December 5, 2006 at 9:22 pm #23121
pmb
ParticipantHi i have a problem Servis M6135 which had originally stopped and would’nt do anything (sorry i dont have any more details on this as a colleague originally went and fitted a module) i went on the call back and now it goes through the cycle ok but after the spin it sits there pumping continuously.About every 2 mins all the lights flash and it makes a clicking sound and goes on pumping until it is reset manually. I checked things like the pressure switch, chamber, heater, motor, valves all seem ok. So i ordered another module, put it on today and it is still the same fault :hmm: any help would be brilliant thanks
December 5, 2006 at 11:44 pm #197070Dave_Conway
ParticipantRe: Servis M6135
Pressure switch or blocked pressure system maybe ?
It sounds like a “I’m not empty yet” problem 😉
December 6, 2006 at 1:07 pm #197071Washman
I have had a similar problem and found that it was the edge connector on module not making good contact ,so now I always squeeze connectors to make better contact.
Mike
December 6, 2006 at 4:38 pm #197072pmb
Hi i did check the pressure switch but i will check it again and the connectors when i go back thanks for the advice guys i will let u know how i get on 😀
December 6, 2006 at 7:15 pm #197073timdowning
I’m sure that when this machine came out there was a problem with some of them not ending the cycle completely. To rectify this you had to change the module. Are they new modules you fitted or recons?
December 6, 2006 at 8:40 pm #197074pmb
They were brand new ones, i normally order recon ones from EMW because they have always given us great service and advice on faults. But this is a job for a warranty company that sends us the parts so we have fitted new ones.
December 8, 2006 at 6:54 pm #197075pmb
DOH! 😕 i was so sure tightening the connectors was gonna work but it hasn’t thanks for the advice though i will tighten the the connections when i change these modules now. The pressure chamber and switch seemed fine too. Any advice on this would be much appreciated as i am pulling my hair out :bang:
December 8, 2006 at 7:14 pm #197076phil59
sounds like a timer fault to me :snigger:
December 8, 2006 at 7:29 pm #197077pmb
:snigger: u got me there for a minute i thought u were serious for anyone that isn’t familiar with these they dont have proper timers 😆
December 8, 2006 at 8:04 pm #197078timdowning
Assuming all contacts are good, no low insulation, no blockages. Two things left.
1) Try a different wall socket. (Had some strange faults on dodgy wall sockets)
2) Give up.
December 8, 2006 at 8:40 pm #197079robbra
On all SUK machines with this type of selector always put dial to stop before reprogramming and wait for the start button to flash.Tell customer to do this every time even if the same prog is required. These can remember parts of previous programmes, ie they spin only, continuously fill or wash forever. This will clear the memory. Had three like this this week. Nice little earner.
RobDecember 8, 2006 at 9:54 pm #197080pmb
Thats interesting i knew problems occured with the Indesits but didn’t know with Servis, although i was testing it and was reseting in between spins. I wish i had tried the plug in another socket. This job is for a extended warranty and the company that gives us the work always choose to repair there machines no matter how many parts need to be changed so thats why i haven’t given up yet. Thanks for all the advice everyone i am very grateful :salute:
January 26, 2007 at 4:28 pm #197081Johnnyboy
I have changed 2 modules on this model and it seems that it does a wash but will not finish, ie continue to end. It does a complete wash, rinse, spin etc but dosn`t finish?????????? Is there a mechanical timer in these? Previously the motor had to be changed due to it shorting out because of a water leak. serious head scratching
January 27, 2007 at 11:39 am #197082smartin
have had the same problem with this machine after picking up someone elses recall, its had 2 modules ,display board,and door switch. i reset it after every try but still made no difference this 1 had been ongoing since nov 06,have now passed it back to insurance company to write off, which i dont like doing. it would be nice to what is causing it if only for future reference.
