Servis M6135 – not going thru cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Servis M6135 – not going thru cycle
  • #38884
    clareba
    Hi.
    My Servis M6135 will not go thru it’s cycle. We have replaced the PCB, and the fault persists. Servis technical have been helpful, but to no avail, and you guys seem pretty switched on (excuse the pun!) so look forward to some help. Another forum suggested that it could be a heater element problem? Trouble is, I don’t want to keep paying out for replacement parts that don’t solve the problem. We live in rural inland spain, so trying to find a technical bod of any sort is nigh on impossible, and the postage costs are astronomical!
    #260249
    petalpop
    Re: Servis M6135 – not going thru cycle
    put the machine on a program and wait about 10 minutes
    if you can`t hear a kettle heating noise it is most likely the element
    if it heats but then won`t finish and is stuck with water in then it is probably the pump or a blocked hose
    that is about as basic as we can get
    if your not sure please post any queerie
