servis M6216al
  • #13518
    pogo
    I have a Servis M6216al washer which last night stop. First it took the main fuse for the sockets out. After replacing this the washer would not start. I have checked the main coming in and I have power right up to the module board. I am now thinking down the line that the module is fault as there is no lights on the front and none of the buttons do anything.
    Can anyone suggest anyother problem that may happen on this machine.
    All the best Andy
    #155323
    Re: servis M6216al
    Pogo,
    Bit tricky to answer but likely the heating element or motor caused the fuse to trip and could also have damaged the Module. So it could be costly to diagnose and fix I’m afraid 🙁
    You could try Repairs@ for a local independent engineer to call in and check it for you 💡
