Servis M6216al …….Help.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Servis M6216al …….Help.
  • #13813
    Jackdaw
    I need to if possible repair a Servis M6216AL washing machine and am hoping someone my have the ‘possible’ answer to the problem.
    I turn it on and start the machine (in any program – it’s the same no matter what I try) and the machine fills up as normal. It then pauses for thought for a minute and then drains the drum of the water and finally after a few more minutes shows end of wash and the door is unlocked.
    Reading one or two other web sites this seems to be a ‘common’ fault with many differing machines, and could point to the motor… or perhaps the brushes. ❓
    Can anyone give me some pointers, help, common reasons and fixes…. Anything which will help me solve this .
    Many thanks
    #156822
    Dave_Conway
    Re: Servis M6216al …….Help.
    It could be worn brushes causing the control PCB to abort the programme, it couls also be the PCB.
    What happens if you put it on “spin only” (if it has that function) ?
    #156823
    Jackdaw
    Hi, yes when it is put onto any cycle it basicaly does the same thing.
    The spin only function (if remember correctly) is combined with a rinse, but basicaly (having tryed about 10 – 15 different program settings and even changing the spin speed (and canceling the spin) it does the same thing – it fills up with water, waits a minute and empties etc etc as it would do normaly
    The drum rotates correctly and looks to be stable, the belt sits comfortaby on rear of the drum and is not slack, and there is no visible evidence of any damage to any internal parts in the upper area of the machine (like leaky pipes). I have not examined the underside of the machine and the motor as of yet….
    thank-you for your help.
    #156824
    Jackdaw
    follow-up…………
    Yes the machine does have a spin cycle but again nothing happens other than the pump to drian the drum works and thats about it.
    Just to note though, I connected an multimeter to the contacts on each brush and then rotated the drum (curcuit connections removed to the rest of the machine) and found that a nominal build up in electrical current was registered on the reading – which I guess would hint that the brushes where likely to be ok **** please correct me if I’m wrong though ****
    #156825
    Dave_Conway
    You’d be better off removing the brushes from the motor and physically checking them to be honest 😉
    Power off please :zap:
    #156826
    Jackdaw
    Hi, just to be sure I don’t damage the brushes trying to check them can somebody please advise me on the best way to remove them.
    There looks to be a unit holding the brushes in place on the motor casing and there is a spade type connecter on the bottom of the brush housing holding a spring and a length of copper wire – am I correct in assuming the spade connector once removed will allow the spring, copper wire and eventualy the brush to be removed and inspected (if its anything like my drills), or will the whole brush housing need to be removed and replaced?
    I dont want to remove the wrong thing and then have extra problems on my hands so any help is gratefully received.
    many thanks. :wave:
    (I’m more attuned to domestic wiring and alarms than mechanics – not that Ill shy away )
