MC wrote:i need a pump for a servis M6500w-1. servis part number is 518008100. but no one seems to have one. is there a different one that could be used?
thanks
518008400 has the same pump motor, the housing is similar but this one has a small drain hose for manual draining, either block this off or just change the motor.
in stock at connect hefty price tho, still searching for a pattern equivelant……..
That is correct. Use small diameter bolts and drill the flanges. I found I had to use a bit of sealant on the gasket due to a slight leak. A fair bit of hassle but you do end up with a much better value pump.
Mike.
Cheers Mike,
Been up to my supplier and we both agree its better than the orig PMP pump from SUK and a lot lot cheaper. I will try the Plaset but it should also work with the Askol.
Rob
