Servis M6505S
  • #40203
    JOHN CLARKE
    Has anybody out there got the part No. for the Door Lock for a Servis M6505S, please? The machine is dead, no lights, no click when the door locks, so I’m hoping I’m on the right track but can’t find the lock anywhere. Please help.
    #265134
    timdowning
    Re: Servis M6505S
    You would still get the lights come on even if the door lock was faulty. check wiring on pcb. if all ok pcb at fault.
    #265135
    robbra
    Re: Servis M6505S
    Hi John,
    Had one today the same and found the no spin button stuck in. Took off the board and released it and “Bobs your uncle”…apparantly. But as Tim says the board also means no light s on the facia.
    Rob
    #265136
    MC
    Re: Servis M6505S
    check button board behind the front facia., usually faulty if no lights are. but if lights come on but door does not lock then it is the main module.
    #265137
    JOHN CLARKE
    Re: Servis M6505S
    It was the module, thanks all who helped.
