Servis M6516W
  • #22786
    Alanj
    Hi Guys,
    been out to this Servis w/m 1600 spin speed. The machine cabinet sides vibrate excessively when there’s a load of any description in it.Has anyone come accross this problem and is there a fix. I have already changed the backplate and bearings and motor. By the way Service technical say it is because it is on a wooden floor, but customer said it did the same on a concrete floor in they’re last house. Any help appreciated thanks.
    Alan
    #196145
    cab
    Re: Servis M6516W
    hi have you checked the suspension legs and where the mouting bracket meets the cabinet?
    cab
    #196146
    Alanj
    Re: Servis M6516W
    Hi Cab
    yes the mountings and susp legs look ok.
    Alan
    #196147
    agro
    Could be the drum spider if slightly out will cause excessive vibration.Poss drum complete
    #196148
    timdowning
    Re: Servis M6516W
    Have seen a number of these under guarantee and just put it down to the design. How long have they had the machine? The fact it’s the same on concrete as well as wooden flooring would indicate they have had the problem for sometime or even since they bought it! I think you may be fighting a losing battle. (perhaps packing the sides with foam would help)
    #196149
    Alanj
    Re: Servis M6516W
    Hi Tim,
    I think it is a design fault that Servis won’t admit to. It’s like some of the earlier Hotpoint machines that needed the sticky tar patches stuck to the inside of the cabinet.
    Alan
    #196150
    Jackal
    Re: Servis M6516W
    Its a Servis – nuff said
    Jackal
    #196151
    agro
    hey guys stop moaning about these bad machine without them wead be skint .I love bad machine
    #196152
    SimonCD
    Re: Servis M6516W
    sticky tar patches are great for fixing vibrating side panels, motor spares suppliers sell them for door panels etc.
    #196153
    nationalhomecare
    Re: Servis M6516W
    Oh dear, so thet’re not getting any better then are they? 😥
    What I used to do is stick a piece of accoustic carpet to the cabinet where that horrid grey spiral fill tube from the valves ratles agaist it, also make sure that the motor bolts are really tight as the rubber bushes vibrate like a good un!
    Top weight is another point of concern especially if stainless tub as spot welds break.
    To be honest theres not alot more can be done and no point in throwing mega bucks at a cheap machine, I just accepted that the price reflected what they were and if customers pay S*1T they get S*1T! They were greatfull we’d turn up and try!! 😆
    On the slower spin machines i also found that the clampband came loose on the backplate 💡
    I know we all knock the merloni but lets be glad its not Domar!
    #196154
    timdowning
    Re: Servis M6516W
    Servis machines have moved on a fair bit since that range, no more backplate clamp bands, no more loose bushes on motor, less module failures. Generally a better machine.
