Servis M6614
  • #43214
    reaper
    Two of these in one day with the same fault! Set on wash – pump comes on for about 30 seconds then machine fills a small amount and then pumps out for a few seconds and stops(it should pause and fill up some more and continue the wash cycle).The machine fills ok on rinse and spins ok.I’ve tried a new module but no joy- any help please.
    #276447
    funkyboogy
    Re: Servis M6614
    is it correct module you are trying ?
    does it fill once and then stop ?
    ally
    #276448
    reaper
    Re: Servis M6614
    Yes its the correct module and it does fill once then stop and the pump comes on for a few seconds.
    #276449
    robbo1973
    Re: Servis M6614
    i had this fault a few weeks ago and it was the board i got a refurb from emw and it still did it in the end ordered a brand new one after checking everything else and now sorted.
    cheers chris
    #276450
    Dales-Electronic
    Re: Servis M6614
    When you say it fills, then empties, then stops, how long do you wait at the stop point? These have a delay after the stop to allow the ping pong ball in the sump to float to the top. Delay can be up to 3 minutes but usually about 1 min. Otherwise as suggested earlier its the module – you can also get the fault that the door wont open on initial test.
