servis m6666
  • #38472
    richardable
    i may be ploughing a lonely and long furrow here but….. customer has one of these and reports that it blows the trips…..not every time but sometimes!!! it washes and completes the programme ….water in, wash action, drain and spin…perfect…then wash rinse drain and BANG!! been twice now and checked wiring, visual inspection of all main components…can i see the wood for the trees…? NO!!!
    richard
    #259022
    aqualectric
    Re: servis m6666
    Have you checked the mains suppressor? They usually fail with a loud bang and some will even continue working while blown. 😉
    HTH,
    Steve.
    #259023
    timdowning
    Re: servis m6666
    Have you checked that the dispenser isn’t dripping water down onto the motor. You should see slight water contamination on the carbon brush terminal.
    #259024
    robbo1973
    Re: servis m6666
    i agree with tim if you check for water signs on the tub under the disp and on the motor.i generally take the disp off split it and d-bore then refit and adj the water pressure i have done tonnes of these.
    cheers chris.
    #259025
    richardable
    Re: servis m6666
    thanks for replies will go next week and report back.
    richard
    #259026
    Bill
    Re: servis m6666
    Be warned it may not be water, but the module and or the motor. I have been to a few of these models and have found it to be the module.
    Bill 😕
    #259027
    richardable
    Re: servis m6666
    thanks bill..i’ll keep an open mind and work through the suggestions.
    richard
    #259028
    richardable
    Re: servis m6666
    thanks everyone….leaking soap dispenser, split, cleaned, debored, all now ok..thanks to you all who replied…much appriciated.
    richard
