servis m6725w
  • #42863
    thesaviour
    when on a 90oc wash it stops during cycle,but all other programes ok.New module fitted and re tagged any ideas?
    #275193
    funkyboogy
    Re: servis m6725w
    try a wash timer, had a few strange faults on these adn fitted quite a lot of wash timers,
    also check heater
    ally
    #275194
    thesaviour
    Re: servis m6725w
    when you say wash timer? do you mean the selecter switch?
    I had a thought about heater as it may be timing out or ntc fault?do you agree
    #275195
    Kirk
    Re: servis m6725w
    Hi this model has a stupid system if 90o wash not used in the first 6 washe’s it is deleted from the memory, I can’t find the mod sheet to rectify this, I have the PDA and reprogram it, The only other way unless someone else has the info is to install a new control board and do a 90 wash.
    Kirk
