servis m6753
  • #59937
    franz
    The drain pump on this wm not running – had been frozen and now leaking – measured resistance o.k – obviously needs pump because of leak – no voltage from pcb to pump – is the board likely to have been fried by the pump trying to turn when frozen? – no sign of any burning etc.
    Franz
    #340132
    suedehead1
    Re: servis m6753
    pcbs easily damaged os servis machines connect up any pump to try it.
    #340133
    franz
    Re: servis m6753
    thanks – tried new pump – no voltage from board.
    Franz
    #340134
    PGS
    Re: servis m6753
    Franz, trace the wiring back to board and check components and tracks in that area.
    #340135
    franz
    Re: servis m6753
    done that mate – board looks like new
    Franz
