SERVIS M6815W
  • #69897
    gadgetdad
    Hi all, visited one of these units today, owner said it tripped the breaker – not rcd last week and will now only fill.
    Stripped motor off and one brush was badly worn and a lot of carbon on motor, blew motor off and replaced brushes but no drum movement still.
    It does make a dull thud when the start button is pressed before it fills – also if set to spin/drain cycle the drain pump only runs for about 10 seconds. Module looks ok as far as I can see, no obvious flashes etc.
    Any ideas ?
    cheers.
    #376386
    suedehead1
    Re: SERVIS M6815W
    the motor has a built in toc which can go open circuit,
    if you have metered the motor you will be able to check it.
    if not its the pcb.
    #376387
    gadgetdad
    Re: SERVIS M6815W
    Ho, thanks for the reply – how do I check the motor – never tried to fault find one with a toc before – cheers.
    #376388
    suedehead1
    Re: SERVIS M6815W
    when you check the motor plug there will be 2 wires which do not have a reading between them and any other wires these 2 wires go to the toc if all wires have a reading then the toc is ok its normally 2 wires in the middle of the plug nos 4 and 5.
