Servis m7006 freezer runs continuously
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Servis m7006 freezer runs continuously
  • #15346
    MattnJake
    The freezer is working well – perhaps too cold. The compressor is constantly running. The cooling vanes are hardly warm suggesting that it should be turning off. Is this likely to be a pcb problem (the lights all work. Incidentally, what is the amber light for, which is activated by the button?), or a problem with the compressor main relay? On first turn on, the red warning light flashes until temperature is low enough, suggesting that the temperature sensor at least is operational.
    #163202
    Dave_Conway
    Re: Servis m7006 freezer runs continuously
    Possibly either the PCB or sensor if it’s getting down to the correct oprating temperature.
    It may be worth putting a thermometer in there though to ensure it is, -18C is the “normal” deep freeze temp.
    The orange light is fast freeze making the compressor run 24/7 if that’s on it will be the problem 😉
