Servis M9010 manual
Viewing 1 post (of 1 total)
  • #60670
    odom
    Would anyone have a manual for this machine? Called out for a variety of faults (the joy of Servis machines), one of which is no airflow through the dryer. The fan motor is spinning up so I guess maybe the fan has come loose on the shaft, but it’s the first time I’ve worked on the dryer part of one of these. Everything looks a pig to get to, shoved in under metal bar with suspension mounted on it :?.
    Thanks in advance. TBH with the amount wrong with it I’d normally have scrapped it but the owner has changed the doors so the machine can no longer be removed – if I can’t fix it, the window will have to be removed!
