Went out to one of these as it was reported leaking. On inspection, I found a hair line crack on a large white plastic chamber that runs up the front right side of the machine about 3/4 of the way up. It connects to the pump. I’m not sure what it does, but it’s the route of the leak. It had been smashed by the lower concrete weight so it must have happened before to someone I’m sure.
Unable to find it on connect distribution…
Help please.
Thanks in advance.
Robert.
Re: Servis M9150W Washer Dryer plastic chamber required
The white plastic pipe from the pump go’s upto the pressure pipe / switch ❓ if so all it is, is a air chamber to feed pressure upto the pressure switch.
