Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Servis M9209 WD 900 – Now the door won’t release …
- This topic has 3 replies, 2 voices, and was last updated 18 years ago by
rfc1795.
March 18, 2008 at 2:50 pm #35386
rfc1795
ParticipantHi
I’m back again for a new problem thats just started. 😕
My wife called to say the door won’t unlock or release after its cycle. She’s even tried a extra rinse spin cycle and leaving it powered off for a long time.
I don’t know if its actually the safety lock mechanism that is activated, or if it is actually just jammed till I see it.
Any ideas as to what this might be, and more importantly, how do we get the door open ?
Thanks… TJ
March 18, 2008 at 11:34 pm #246367rfc1795
ParticipantRe: Servis M9209 WD 900 – Now the door won’t release …
Ok, I’m stumped … just spent over an hour trying to figure this one out and could not get the door open. The door is not jammed, looks to be the safety lock that is not disengaging.
Any ideas or advise as I need to get the washing out before it goes mouldy 😆
March 19, 2008 at 1:24 am #246368Penguin45
Unplug it, then remove the lid. With the power off, the lock should dis-engage within a few minutes. If it does, you have a problem with the controls, which would be unusual. If it doesn’t, either the handle is broken or the lock itself has failed. The lock can be reached by delving down the inside of the machine and feeling for the point of the door latch – you can push it aside to pop the door. If you can’t, you will need to break the lock to release the door.
There are early and late versions of this machine, so if you do need to break the doorlock the serial number will be required to identify a replacement.
March 19, 2008 at 10:34 am #246369rfc1795
Penguin45 wrote:Unplug it, then remove the lid. With the power off, the lock should dis-engage within a few minutes. If it does, you have a problem with the controls, which would be unusual. If it doesn’t, either the handle is broken or the lock itself has failed. The lock can be reached by delving down the inside of the machine and feeling for the point of the door latch – you can push it aside to pop the door. If you can’t, you will need to break the lock to release the door.
Thanks for the reply … we’ve got the lid off … just need to figure out how to dis-engage the lock now. It’s a tight fit in there. Will try the break in approach 😆
