Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Servis M9309 Internal Hose
- This topic has 7 replies, 5 voices, and was last updated 20 years, 6 months ago by
Phidom.
October 13, 2005 at 1:32 pm #12556
ParticipantThis machine has very dodgy internal plumbing with not one but 3 hoses that rub on the left hand suspension spring 😯 .The one I need is the hot feed from the valve to the front of the soap drawer housing.The other 2 have some foam lagging round them but not on the hot so I don’t know if this should be the same. Anyone got a part number? I have wondered whether to just use a length of the nylon reinforced hose which may not wear through as quickly.
October 13, 2005 at 3:04 pm #150260Washman
ParticipantRe: Servis M9309 Internal Hose
Part No 414008200 .
But I would just use standard valve hose. And be careful with how you route it so that it can’t rub.Mike
October 13, 2005 at 6:45 pm #150261Phidom
Thanks Mike, I’ve never seen this type of hose available by the metre so I will probably just get the proper part.
October 13, 2005 at 6:58 pm #150262admin
KeymasterRe: Servis M9309 Internal Hose
I seem to recall that a standard inlet hose with the end cut off fits well, and is far better quality than the manufacturers offering, plus 2 jubilee clips.
Kevin
October 13, 2005 at 7:37 pm #150263iadom
ModeratorRe: Servis M9309 Internal Hose
kheath wrote:I seem to recall that a standard inlet hose with the end cut off fits well, and is far better quality than the manufacturers offering, plus 2 jubilee clips.
Kevin
By eck, old dog, new tricks…done that for years, dip the end of the hose in a cup of very hot water to soften and it will replace most basic dispenser inlet hoses, and you will get 3 to five hoses for the 75p cost of a single fill hose.
October 13, 2005 at 9:53 pm #150264Phidom
Thanks, will try that. I’ve usually got a few Zanussi hoses with the special flanged washers missing so I could use one of those. 🙂
October 13, 2005 at 11:29 pm #150265Penguin45
Splash out! Go mad! Cut up a new one!
October 14, 2005 at 8:29 am #150266Phidom
The grey rubber Zanussi ones seem more flexible than the harder red and blue plastic type though 😉
