Servis M9310W Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Servis M9310W This topic has 2 replies, 2 voices, and was last updated 17 years, 1 month ago by rocker. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts February 13, 2009 at 10:04 pm #43462 rockerParticipant Customer tells me cant open door, although the machine appears to still run through cycles ok, so I am presuming only the interlock has a fault, but can anyone tell me if there may also may also be a fault on the pcb module.(as hotpoints do) John. February 14, 2009 at 6:38 am #277335 timdowningParticipant Re: Servis M9310W I doubt module has fault. On that model it could just as well be the door handle. The metal pin which pushes through the hook and spring can just come out of allignment. If you open the door from inside you can then take the outer trim partially off and re-allign handle parts. Check the clear plastic part of the door handle hasn’t got a fracture in it. February 14, 2009 at 12:38 pm #277336 rockerParticipant Re: Servis M9310W Timdowing, thanks for advice. john Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
