The blower fan on this washer/dryer is running ALL THE TIME, even throughout the wash cycle and as soon as you switch on!
I can’t suss it out other than to suspect the Dryer Module is at fault here? I was wondering if anyone could agree or not with my brilliant guess-like diagnosis? 😕
Just a suggestion Martin….if the dryer has an overheat stat or thermistor then it may be faulty giving an overheat reading causing a default ‘cooling’run on the fan?
If not then I think you’re on the right lines with the module 😉
Martin, don’t forget we sell over 60 different types of these Servis boards inc brand new ones ( £25 – £29.90 + vat inc post) so they don’t need to be a fortune. Need the 9 digit code starting with 546…..
Tony
EMW
