servis m9310w no spin
  • #62075
    Johnnyboy
    Last one… replaced module and motor on this one because it wouldnt spin, left it spinning quite the thing, call 3hrs later wont spin, aaarrghh, same as last time the drum slowley rotates left and right but wont get up to full speed, she has tried reducing the load amount to no avail, 92 mile round trip anything obious missed.
    Cheers Johnnyboy
    #348559
    machineman
    Re: servis m9310w no spin
    Tell them to try it empty of clothes
    if it works with nothing in its uneven load
    Allsorts
    Check the pressure switch too .. if the P?S thinks it still has water in the machine it will tumble but wont spin.
    Had this last night on a M6012
    George
    #348561
    robbra
    Also check the belt is dead tight, the slightest flexiness?? in the belt can give symptoms of an uneven load. I always change the belt on a no spin before anything else.
    #348562
    Johnnyboy
    This is a funny one its similar to the Hoover fault, the main wash heater had a low reading so I replaced it and BINGO!
    Thanks for all the help Cheers Johnnyboy
