Servis M9503 Tripping Electric
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Servis M9503 Tripping Electric
  • #60616
    Allsorts
    Servis M9503 Washer Dryer
    Ser: 20072307650-0140 77 068-01 02
    This machine is tripping the RCD that covers the plugs and cooker.
    The RCD only trips when the machine is on wash (not dry) and goes into either a short or a long spin… It does not trip when the machine tumbles.
    The machine had a replacement motor in October when the machine had the exact same problem.
    Any thoughts on the cause of this would be appreciated…
    George
    #342932
    suedehead1
    Re: Servis M9503 Tripping Electric
    wire chaffing on tub if it has a metal tub.
    #342933
    funkyboogy
    porr quality motors as well george , when we were servis agents we repalced plenty and on a regular basis ..
    also maybe leak onto motor ect ..
    have fun
    ally
    #342934
    chezza
    suedehead1 wrote:wire chaffing on tub if it has a metal tub.
    Yes , had one of these like that ….. if I remember, it was catching on a very serrated unfinished tank seam . worth a check
    #342935
    Allsorts
    Does anyone have the service info for this machine? if so, can I have a copy please.
    Might as well go out to it and just confirm if the motor is gone or not.
    George
    #342936
    chezza
    You have mail George , hope it helps
    Eddie
    #342937
    Allsorts
    Thanks Eddie … Unfortunately. It looks like the machine is completely different.
    George
    #342938
    Lawrence
    disp leak from the back down the side into motor ,also if its stainless tub look for thye loom near the door lock chafinng on a very sharp lug
    #342939
    happycack
    Thought the ring main (sockets) would be seperate from the cooker (radial) unless it’s taking everything out? Out of touch with house wireing these days.
    #342940
    Allsorts
    No… you are not out of touch… This flat has a ring main that covers all plugs and the cooker…
    I questioned this with the tenant and he tells me that he has spoken to his landlord about it.
    George
    #342941
    happycack
    Electric cooker or just gas hobb ignition and lights etc.?
    #342942
    Allsorts
    Electric cooker (Stand Alone)
    George
    #342943
    If it has those plastic convoluted hoses from the inlet to dispenser, the ones with v joints, check for leakage from there. They seem to leak for fun and also get abraded by the rough edge of the plastic condenser housing a few mm away. Resulting in a drip or a stream onto motor.
    Mike.
