Called to above. M/c fills then tumbles for a short while, then the motor appears to be labouring and option leds flash intermittedly, then motor will only turn a quarte of a turn. I then reset prog and selected spin, the pump operates ok and drum distributes, them m/c appears to cut out then start the above again never going into full spin. Is it board and motor or just board. Cheers Guys. (serial 20074211047)
