Servis M9503W
  • #73817
    aqua_serve
    Webt to this machine the other day with a pumpp fault, checked the voltage and found it varied from 200-800V at the terminals.
    Am I right in thinking this is an issue with the module? Would I also be right in thinking that Servis parts are becoming harder to source?
    Mark
    #388899
    Re: Servis M9503W
    I would question your meter TBH….. 800 volts….do what, blimey???
    Plenty of parts about for these machines. EMW can check out the module for you if you have any worries there. The pump is a regular Askoll. 😀
