Hello,
The above washer dryer when turned on all the lights light up door wont lock machine is other wise dead.
Module looks ok poss door lock?
When it had finished last wash water was left in machine.
Would suspect pump but dorr wont activate to give any faults to test.
Drain the machine manually first, check filter and retry. If there is still nothing, try an interlock: then it will be PCB. ‘Machine dead’ is a common fault on Servis washers – EMW do a selection of these PCB’s and may be able to test yours for function. (01159) 652118.
Almost certainly PCB failure. 😉
