Servis M9503W not filling no power to the valves
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Servis M9503W not filling no power to the valves
  • #54762
    johnnyhoz
    Suspect the pressure switch is faulty, is the test for it straight forward should I find a N/O & N/C contacts?
    If it checks out OK would it be the module?
    Any sugestions would be gratefully received
    John
    #320905
    timdowning
    Re: Servis M9503W not filling no power to the valves
    Have you seen the machine yet?
    One of the valve coils may be open circuit.
    Do check the module connections on this model as they have a tendancy to melt.
    Also check the wires to the pressure switch, they can melt as well and give you a no fill fault.
    #320906
    johnnyhoz
    Thanks for the advice Tim
