Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Servis M9503W washer-dryer dead
- This topic has 10 replies, 4 voices, and was last updated 13 years, 6 months ago by
dave_525.
September 25, 2012 at 12:47 pm #71654
dave_525
ParticipantInherited this when buying a narrow boat. Previous owner says it was working but it is dead. There is power at the socket, checked the plug fuse, checked the double-pole on-off switch, replaced the door interlock switch. Can’t see anything disconnected or charred inside. What should I try next? Replacing it would be a nightmare.
September 25, 2012 at 1:21 pm #381826Muv
ParticipantRe: Servis M9503W washer-dryer dead
Have you got continuity from your live & neutral at the plug, to either side of your mains suppressor..?
This is attached directly at the end of the mains cable… If not there’s your problem…
September 25, 2012 at 1:25 pm #381827Muv
Don’t check anything with power connected. Zap!
September 25, 2012 at 1:41 pm #381828dave_525
At the top rear where the cable comes through the back panel?
September 25, 2012 at 1:44 pm #381829Muv
Yes there ..
September 25, 2012 at 2:19 pm #381830dave_525
That checks ok Muv. Must be something else.
September 25, 2012 at 2:40 pm #381831Muv
Do you have any power light illuminated at all on the machine?
If not I’d check continuity down to the interlock. If that’s ok then you probably have a fault in the main power board. Or maybe a loose connection there…. Time to call a qualified engineer then!Sorry I cannot go in to further detail with this..
September 25, 2012 at 3:00 pm #381832dave_525
Is the interlock switch a straightforward changeover switch or is it more complicated than that? Trying to check the new one and getting myself confused.
September 25, 2012 at 3:07 pm #381833bazza500
This machine had a common fault with resistor R1 on the board going open cct causing the machine to appear dead.
September 25, 2012 at 7:26 pm #381834dave_525
I see now how the interlock switch works – live incoming to pin 3 neutral on pin 1 and the switch operates (if the door is closed) and you get live out of pin 2. I’m not getting neutral continuity to pin 1 though – where does this neutral feed come from? Presumably a sensor that says if there is still water in the machine?
September 25, 2012 at 7:37 pm #381835timdowning
do check for broken wires on the pressure switch. power off of course!!!
