Servis M9713 XXL
  • #13298
    epidot
    I’ve had a Servis M9713 XXL Washer Dryer for a while now and it seems as if it doesn’t dry my clothes anymore when using the dryer.
    Is there an easy way to fix this? I guess there might be some filer that is full of fluff or something?
    #154126
    Re: Servis M9713 XXL
    Tricky question with a dozen possible options owing to the complexities of your machine. (i.e condenser blocked, water inlet fault, pump, programme, elements or thermostats????)
    If you are the least bit unsure, I would honestly suggest professional help. Try one of our local independents repairers here
    #154127
    epidot
    Well,
    the washer part of the machine works fine, the dryer works in the sence that the clothes get warm. There is water coming out from the outlet during the drying but the clothes are still wet after being through the process.
    I guess I should get someone out to have a look at it
    Cheers
