servis module
  • #47780
    ELDAR59
    can anyone confirm that part number 546089203 is the module for a servis w/m, model number M6652W, serial number 20081003928?
    also would anyone be able to supply part number for drain pump for same machine?
    a supplier would be very handy too! 😳
    thanks.
    #294588
    chalky
    Re: servis module
    Tried Tony @ EMW?
    #294589
    petalpop
    Re: servis module
    as memory serves
    the part number for it will be printed on the old p/c/b
    #294590
    Re: servis module
    You can just about read that number 546089203 off the enlarged pics on connections. I would say that was correct.
    Connect also have a drain pump for it under their in-house number :rolls: 5045173407565 at £34.82 😯 but it looks like any Askoll/Plaset three screw pump would fit. Looks like original has TOC, but you could probably use coil from old one if it’s not burnt out.
    Mike.
    #294591
    Dales-Electronic
    Re: servis module
    Just be abit canny with the drain pump as there were two types fitted, the original one had a bayonet fit whilst the later on had screw type (Askoll or Plaset – also note that there are two sizes of pump on the screw fit ie the old servis pump from earlier models does not fit the later) If the module is a 546089203 remember that this on connection is reprogrammed by the facia board. If this is also stuffed (very rare) you would need the Servis PDA to reprogramme it.
    #294592
    ELDAR59
    Re: servis module
    thanks for your help guys!
