Servis Module
  • #50542
    pmb
    M9010w,
    Block connector on the end of module burned and module damaged,
    Suspect water dripped on it.
    Number on old module 546052200
    number on new module 546052201
    New one has plastic surround for connector block to locate but you have to
    cut locating bits off plug to make it fit
    When fitted, All programmes wrong, spin is rinse, wash might be wash etc
    Both Connect and Masterpart show this to be right Module,
    Is their a modification or are they supplying wrong module
    #305204
    bazza500
    Re: Servis Module
    Do you have serial number of appliance?
    #305205
    robbra
    Re: Servis Module
    These modules often burnt and if you had to break off the old plastic plug and replace with amp tags then you could have put the wires back incorrectly. The wires will have numbers on them, 1-10 so make sure they are in order. The 1 on the module no. is just the supplier to Servis but if the old module was there from new then you have the right part.
    Rob
    #305206
    pmb
    Re: Servis Module
    Serial No 20034122801
    I hack sawed only two connectors off end and put tags on.
    No mistakes
    #305207
    robbra
    Re: Servis Module
    Module definitely correct. As you will know the module controls everything on this machine and there are no modifications so perhaps it is faulty from new which is not unheard of but unusual. I’ve never come across this particular problem so have suggested all I can.
    Good luck and I will look forward to the solution.
    Rob
    #305208
    mike1
    Re: Servis Module
    Did you get to the bottom of this problem as I have the same problem and have tried 2 x modules?!
