Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › servis no drum turn
- This topic has 12 replies, 8 voices, and was last updated 20 years, 3 months ago by
abbots.
January 11, 2006 at 12:02 pm #14710
abbots
Participanthi guys,
servis m6216al no drum action at all,completes wash program to end but no drum action.
about 2 years old,checked obvious,belt,cb’s,wiring.
what do you think mod maybe?
any ideas where to obtain.wash vac and electrue have not got.
no. on mod 546039600-01 minisel
cheers jkJanuary 11, 2006 at 12:46 pm #160526Del
ModeratorJanuary 11, 2006 at 1:57 pm #160527abbots
ParticipantRe: servis no drum turn
cheers mate
January 11, 2006 at 3:37 pm #160528robbra
Under guarantee I find many have loose motor connectors but if this is ok best bet is module
RobJanuary 11, 2006 at 3:55 pm #160529Bill
Del,
QER are not very good at repairing Servis modules!
Bill Ellis :scot:
January 11, 2006 at 6:14 pm #160530leavemetogetonwithit
Check module visually. You might find signs of burning round a relay terminal. Bit of sand paper and a soldering iron will usually fix that. Check resistance of any large resistors on module. If any open circuit replace w same value. There were some offers of Servis modules in classified forum a few months back. Try a search.
Mike.January 11, 2006 at 9:16 pm #160531Penguin45
Bill wrote:QER are not very good at repairing Servis modules!
But EMW are……….
January 11, 2006 at 9:48 pm #160532aqualectric
Run a spin cycle with a reasonably balanced load in the drum (they don’t like spinning empty). Also try unplugging the heater then try spin again as if there is a small earth prob with it module will not spin. EMW are excellent at these modules; I’ve fitted quite a few never had a problem.Also Tony is a veritable goldmine of tech info on known faults (and things to test) on all the modules they stock. Most of all, they are quicker than Servis to supply, same 12m warranty,cheaper by loads, and if you diagnose wrongly and it still doesn’t sort the fault you can send it back for £4.70! Almost as good as a library! 🙂
January 11, 2006 at 10:27 pm #160533abbots
cheers guys
jkJanuary 11, 2006 at 11:31 pm #160534robbra
Just an aside.
Servis UK only guarantee their parts for three,yes THREE months so wherever you source has to be better and EMW are the best at service and qualityJanuary 11, 2006 at 11:36 pm #160535robbra
And another thing. Servis Uk machines Do love to spin empty providing the belt is tensioned, in fact that is the best way to test them if a customer complaines of no spin,I always say if it reoccurs try it empty before calling again and also after working on A Merloni machines since 1990 I have never seen an element fault cause no spin
RobJanuary 12, 2006 at 8:03 am #160536abbots
ok guys,
thank,lots of information for me to look over there,
so do i presume the mod could be the source of the problem?
jkJanuary 12, 2006 at 8:07 am #160537Martin
abbots wrote:so do i presume the mod could be the source of the problem?
Without any doubt 😉
