Model 9545.
Leaking through seal but bearings are ok. This is the plastic tub with needle bearings.
I’m presuming there is supposed to be a crush washer on as well which is absent on this.
If this is still available what are the part numbers and is there anything to look out for as I’ve never done this type of bearing before.
Maddocks do a kit that covers the Servis Quartz and many other models: 05-SV-06. I’m almost certain it would do you in you need to replace the bearings and seals.
