Servis t/dryer belt failure.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Servis t/dryer belt failure.
  • #23469
    megawatt
    Called out to a snapped belt on a M2010. Drum OK, fitted a 416001601 and tested OK. Called back next day to find new belt snapped!
    Is this a one off, or is this a common problem?
    Mike.
    #198229
    Washman
    Re: Servis t/dryer belt failure.
    Its a common Fault on these. Elasticated belt with a lot of tension on it.
    Mike
    #198230
    nationalhomecare
    Also had back rubber/felt bearing go sticky on these and snatch the drum when they warm up making the drum difficult to turn. 🙂
    #198231
    robbra
    Yep, stick some grease between the rear seal and drum, been doing this for years and never gone back to one
    Rob
    #198232
    megawatt
    Thanks for your comments guys, I’ll remember them for next time.
    Mike.
    #198233
    Marty-K
    robbra wrote:Yep, stick some grease between the rear seal and drum, been doing this for years and never gone back to one
    Rob
    What type of grease do you use ❓
    #198234
    robbra
    High melting point grease(about £2.50 a tub in car shops) I use for taper bearings, not too much mind, just enough to get rid of the grip the seal has on the drum and stop the squeek.
    Rob
