Servis Tumble Dryer M2002S
  • #32733
    Kez
    Has anyone else experienced repeated problems with the on off switch for this tumble dryer?
    It is a switch with a small pcb on the back of it and we have changed three switches now inside three months on the same tumble dryer.
    I am wondering if there is something else causing the switch to fail. It works ok for a month before failing again. Just a poor quality component or something else? Any ideas welcome!
    #236218
    robbra
    Re: Servis Tumble Dryer M2002S
    This small board takes the whole load of the machine and do fail often as you have found out but I’ve never had three on one dryer. Is the dryer venting properly or in a damp place as I have found condensation can be a problem inside the cabinet and could cause failure.
    Rob
