Re: Servis W/m
robinsonrobbo wrote:check earth leakage on heater just pull off the wires and try it had this before. also check belt tension should be bow string tight.
Yep have checked for open circuit and earth fault.
I know in the past repaired boards dont always work, have replaced them with new, then it seems to be ok, may have to do that with this one.
Trying to keep the cost down by repairing pcbs sometimes costs you more in the long run.
