Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Servis w/m door/interlock prob
- This topic has 10 replies, 8 voices, and was last updated 19 years, 9 months ago by
silverbroom.
June 15, 2006 at 9:38 pm #18516
silverbroom
ParticipantHi, any one come across this, Servis W/M model M6011S ser 20044411563 18 months old, job last week interlock not engaging when door closed. interlock checks out OK and machine works if lock operated via manual manipulation with screwdriver so must be door pecker. ordered kit from GB DAR and fitted it, still same prob, now have another customer phoned to-day Servis M6003 ser 20044315690 about two years old, going on Sat but by customers description same prob.
Asked GB DAR parts if any mods for above models but said no, sorry for long winded explanation. Thanks for any help.
Victor.
June 15, 2006 at 11:42 pm #179284deltra
ParticipantRe: Servis w/m door/interlock prob
hi victor, try taking the outer/inner door trim off,(just clips together)and see if door lock then engages properly. sometimes these door trimscan slip and stop door from closing properly 8)
June 16, 2006 at 8:34 am #179285Washman
Allways change door interlock and handle kit together . I find that cures the problem every time.
Mike
June 16, 2006 at 2:14 pm #179286silverbroom
Thanks for your reply Washman and Deltra will see how I get on with Saturdays call, now have a new interlock so will go back to previous customer and try this plus door trim thingy.
thank you both once again for your input.
Victor.June 16, 2006 at 6:57 pm #179287wilf
Ive had this, seems to be no reason for it. changed interlock, catch even door, filed bits off back of catch final straw found a second hand lock. no call back thank god
c**p machines always cause more problems for less profit plus they are usually in c**p houseswilf
June 16, 2006 at 7:03 pm #179288Martin
wilf wrote:they are usually in c**p houses
How true an observation that is 😉 I cringe when someone phones me and says “Do you fix Servis washers….mate?”
That gives me a clue for starters…………. 🙄
June 18, 2006 at 10:48 pm #179289cornwell40
Bit off topic, but Martins comment about ‘MATE’ from customers reminded me. I absolutely hate it when customers get over familiar (unless I know them very well), knowing my name and using it as a punctuation for every sentence!!! 👿 The MRS once took a call and was surprised I hadn’t mentioned this best mate before……….he had my card, thats all.
I’m a sole trader but I prefer my trading name to be used.TC
June 19, 2006 at 12:00 pm #179290silverbroom
Went to my Sat call had new lock and handle kit just incase, decided to try the tip from Deltra so removed the outer door trim only, closed door and hey presto machine works. Put outer door trim back on and problem returns. The trim is very thin and would do as a Rolf Harris wobble board, you can see it actually move and warp as you close the door and must hamper proper connection.
Removed trim again and yes it works, as the machine is in a utility room
customer is happy as long as it works and I can see no unsafe aspect with this solution. Customer admitted that under guarantee she called engineer out from Servis who after some deliberation said he did not know what the problem was and then left.Went out to-day to my other Servis as mentioned at start of this enqurie and carried out same routine and again it worked.
Thanks to all for your input.
Victor.
June 20, 2006 at 5:24 pm #179291roly16
Martin wrote:
wilf wrote:
they are usually in c**p housesHow true an observation that is 😉 I cringe when someone phones me and says “Do you fix Servis washers….mate?”
it’s not as bad as “Do you do free call-out MATE?” 🙄
June 21, 2006 at 6:52 pm #179292wilf
“No I dont want you to call out I just want you to tell me whats wrong with it Ive got a mate that can fix it, he’s an expert” 🙄
wilf
June 23, 2006 at 11:18 pm #179293bigkid
Dont forget good old John….
“Hey John, do you do washing machines?”
My usual reply is, “How did you know my name?”Tony
