The customer complains that after pressing the start switch nothing happens for a short period then begins to fill but almost immediately begins to pump out and then the proramme ends.
Any pointers towards what might be causing this would be appreciated.
A routine check is failing and the programme is aborting.
Fraid its leg work required to look for why its aborting…open circiut heater and dry joints on the module being the 1st things to check, don’t forget the motor brushes being open circuit, it does/ should do motor action b4 it fills momentarily.
