got a m9503w washer dryer. all that happens is all lights turn on and you cant select any programs. i think it is the minisel modual. just wondered if any one has had problems with and other boards in this machine
been to a few of these where all pcb needs changing,
ie main pcb , dryer pcb, led displays, on of led …
they are a total nightmare…… run if you have the chance
If all the lights progress lights are on but won’t programme then should be the dryer module but if it energises the valve for a split second probably the module. Parts getting harder to source other than the main module via EMW. I wouldn’t now touch one without spare parts in my van or under an extended warranty.
Rob
