SERVIS WASHER DRYER M9150 BLOWING F9-F10ON MODULE
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SERVIS WASHER DRYER M9150 BLOWING F9-F10ON MODULE
  • #15992
    ttcchh
    Just had PCB back blown across f9-f10 on PCB..We only do a few of these and have no tech info…..Can anyone advise cause of this as concerned will blow again as soon as new one fitted. Have been advised that motor and heater etc chack out ok ❓
    #167115
    Dales-Electronic
    Re: SERVIS WASHER DRYER M9150 BLOWING F9-F10ON MODULE
    Hi – F9 goes to heater. F10 to dryer board. We have had afew problems with both the modules and the edge connectors on these. If you want a circuit diagram sending up PM me and i’ll send it as an email attachment. Good luck – Ian
    #167116
    ttcchh
    Thanks Ian
    In your opinion is it one or the other ? or does remaking the connection tight on a new module cure the problem ? The tags are 1/4 blades and I was going to cut the loom and tag seperatly with covers to ensure a good connection….what do you think
    Many thanks
    Tony
    #167117
    robbra
    That’s what I always do, Ian, and never any problem since. The connections are just too flimsy to take the current.
    Rob
