servis washer dryer m9503w
Home Forums Public Support Forums Help And Support Washing Machine Help Forum servis washer dryer m9503w
  • #61997
    physics2
    have a servis washer dryer which has decided to stop spinning or tumbling,but will fill and empty okay.
    my wife has said she pushed the draw back and thats when it went faulty.
    she has a habit of switching through the cycle to speed things up if this may have caused the problem??.
    can anyone assist please.
    #348355
    Re: servis washer dryer m9503w
    Module probably knowing Servis. :rolls:
    Allsorts
    Several things could cause this. Pressure switch, Motor brushes, Motor, Loom connections, or as Kwatt has said, the PCB Module..
    You will need to get an engineer to look at this unless you are proficient to check the individual componants yourself.
    Always remove the plug before attempting to have a look yourself.
    George
