Servis Washer M6006 – No Power
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Servis Washer M6006 – No Power
  • #39634
    coda2
    Symptoms – Machine won’t operate on any program and front neon not illuminated!
    Fault Finding – Checked plug fuse, internal filter, washer ON/OFF switch and the electrical operated door switch interlock. All power and necessary interlocks to perform at least a spin cycle are present.
    Have looked at posts here for other Servis washers and the pcb appears to be the culprit!
    Any help would be greatly appreciated.
    Regards
    Mike
    #263027
    suedehead1
    Re: Servis Washer M6006 – No Power
    sounds like the pcb plug out please.
    #263028
    helo_75
    landfill
    #263029
    coda2
    Thanks for the feedback and appreciate the economics for the washer going in landfill it’s a no brainer – but to someone of limited income then a different approach is needed.
    I volunteered my services to an elderley neighbour who hasn’t a lot of money – as the washer is 2 years old I’ll obtain a new pcb from Dave for £80
    Mike
    #263030
    Lawrence
    Be Careful, you may spend £80 on a PCB and find something caused it to blow in the first place ..
    I know it’s only two years old but you could end up throwing a lot of money at it .
    Lawrence
    #263031
    cockney steve
    I’d concur with lawrence’s comments….have you checked the heater , motorand pump are all OK? no internal shorts? not leaking to earth?
    If money’s that tight, consider an older machine which is designed to be mendable, from a charity shop/recycling centre.
