servis washing machine
  • #8068
    Hi all,
    Just want to say what a lifesave this place is, so thankyou all.
    Now for my current problem:
    Our servis washing machine has developed a misaligned drum . If you look at the front of the machine the outer container appears to be correctly placed, however the actual drum itself is way off to the left, to the point where it is almost touching the outer.
    I hadnt noticed this as the machine still runs through the cycle without problem, however a couple of days ago it started leaking a small quantity of water on to the floor which is when I noticed the off centre drum.
    Is this something that is fixable by a keen DIYer or is it likely to be an engineer job
    I dont have the make handy but I do know its only one of the £250 ones 😕 😕 😕 😕 😕 😕 😕 😕 😕 😕 😕 😕 8) 😕 😳 😛
    #126700
    Re: servis washing machine
    Sorry, didnt mean to post all those smilies, they didnt show up when I entered the message only after it had posted!!!
    #126701
    Dave_Conway
    This could be major if the drum itself has buckled, although one complaint with these is the backplate spinning around which would also explain the leak.
    Have a look at that as I think that’s where the problem lies, if it isn’t it’s probably time to replace it Andy.
