Servis Washing MAchine Noisy when filling
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Servis Washing MAchine Noisy when filling
  • #55427
    sjd1869
    Hi All,
    We have a Servis Washing machine that runs fine apart from t he fact that now when the machine is filling with water it makes a load noise
    Any ideas as to what it might be
    I did wonder if the inlet pump or valve was on the way out
    Any Help is Appreciated
    Simon
    #323652
    Kevin
    Re: Servis Washing MAchine Noisy when filling
    What type of noise ? When the machine first starts prior to filling it will drain it may be the drain pump that you are hearing possibly a loose impeller or debris in the pump. However when the machine starts to fill there is only the water valves open and they should be silent apart from the in rush of water noise
    #323653
    sjd1869
    The noise is like the noise the machine makes when filling but its just louder and sounds unhealthy
    Its difficult to describe
    Regards
    Simon
