servis washing machine not working
Home Forums Public Support Forums Help And Support Washing Machine Help Forum servis washing machine not working
Viewing 15 posts - 1 through 15 (of 18 total)
  • #52491
    paul161201
    My washing machine has broken down first their was no power The fuse had blown in the plug. I replaced the fuse
    Now the lights come on as normal you selet the program and it doent do anything?
    What is the most likely problem?
    The machine is a servis washing machine.
    I also had a look at the interlock i metered it out for continuity opening and closing the catch with i screwdriver and had no continuity
    #312016
    Re: servis washing machine not working
    Exploding pcb was always a good one with these. What’s the model number?
    paul161201
    where to are the PCBs located inside the machine?
    #312018
    paul161201
    If the PCB Exploded would it pop the main fuse in the plug?
    #312019
    Yes.
    Model number….
    paul161201
    im not sure of the model number will look it up when i get home tomorrow
    Where too are the PCB located i will have a look at them.
    #312021
    helo_75
    depends on the MODEL number
    #312022
    paul161201
    I done a search on Google images and my machine looks like
    it a Servis washing machines M6500
    I will be able to confirm it tomorrow
    #312023
    paul161201
    The model is Servis washing machines M6500
    #312024
    PCB should be in the top right rear corner in a white plastic box. Damage is usually pretty obvious, most notably the connector block at the rear.
    Spankplanker
    Hi Folks. First post on here, so please be gentle! 😉
    My 7 year old Servis M6216AL had its first breakdown last night, suffering from similair symptoms to paul161201, except the lights remained dead after changing the fuse. 😥
    After opening her up, I’ve traced the fault to the PCB’s connector block exactly as described by Penguin45. It’s a bit blackened and it actually looks like two of the spades have fused together inside the connector block.
    I’ve seen a new module advertised online for £39.90, but was wondering if anybody knows if it’s worthwhile getting out the soldering iron out to try and repair the terminals or if it would just be a waste of time? (ie if the circuit board could be fried internally)
    Any help gratefully appreciated,
    Andy.
    #312026
    paul161201
    Sorry had a look at the machine and i got the model number on the inside of the door.
    The model is M6515S
    i also notice that the lights flash and the start light does not come on when you push the start bottom.
    #312027
    paul161201
    Spankplanker wrote:Hi Folks. First post on here, so please be gentle! 😉
    Andy.
    Check the tracks on the back of the board if they are burnt try to bridge
    over the broken track
    #312028
    paul161201
    I found the PCB board and 3 of the terminals are badly burnt the plastic cover on the terminals was also melted. I have taken
    I taken some pictures
    The tracks around the terminals has burnt away do anyone have a picture of the track layout so i can repair the track?
    The serial number on the board is 546056000
    If not do anyone now the price of a new board and the terminal block
    http://s805.photobucket.com/albums/yy340/paul161/
    #312029
    *Sigh* Two problems running in one thread – I wish you guys wouldn’t do that….
    Right. The two terminals at the edge of the board are a pair, so should be joined together, the third one is not. Scraping off all the carbon is a good starting point. If you think that a solder repair can be made, use bridging wire to reinforce any joint. The multiway plug is not a spare part, so you’re looking at replacing the individual terminals with AMP tags. Don’t use those horrible red and blue plastic sleeved things as they won’t last.
    The only guaranteed repair is to replace the board. The “546—–” number is the actual part number. Repaired/refurbished boards are available at a sensible price with a mild amount of Googling.
    It’s unusual for the pcb to damage other components when they do let go.
    Bear in mind that these are budget appliances and there is no factory support (It was pretty laughable anyway) available, as Servis is now bust. All these machines are on borrowed time.
