Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Servis washing machine starting switch not working
- This topic has 15 replies, 4 voices, and was last updated 2 years ago by
Bigdad.
March 14, 2024 at 9:42 am #102648
Bigdad
ParticipantServis washing machine starting button not working no light on the starter button but all the other lights on the interface control PC board comes on please can anybody help 🙁
March 14, 2024 at 10:14 am #489823electrofix
Moderatorfrom what a can remember this light does not come on till the door locks
i would check the door lock first
have deleted you 2 other duplicate posts
March 14, 2024 at 10:33 am #489824Bigdad
ParticipantThank you for your help it’s well appreciated dave blessings
March 14, 2024 at 10:37 am #489825Bigdad
ParticipantDoes anybody know where I can get a door lock for servis washing machine front loader model number M6755W or what’s compatible door lock for this model??
March 14, 2024 at 12:15 pm #489826don
ModeratorFrom our own shop it says it’s this one https://shop.ukwhitegoods.co.uk/530001500-servis-hygena-washer-washer-dryer-door-lock
Don
March 14, 2024 at 12:24 pm #489827Bigdad
ParticipantThanks Don well appreciated
March 14, 2024 at 6:22 pm #489828Bigdad
ParticipantHi Don where can I get the washing machine door lock from which you showed me earlier product code “SKU#D121071 you said I can pay on amazon “how” please advise it will be well appreciated hope to hear from you soon also I’ve looked on amazon for the door lock but I can’t see it can any one help??
March 14, 2024 at 6:54 pm #489829don
ModeratorAmazon?? No, you can get it from our own shop. click this link to get to it to order https://shop.ukwhitegoods.co.uk/530001500-servis-hygena-washer-washer-dryer-door-lock
Don
March 14, 2024 at 10:20 pm #489830Bigdad
ParticipantOK Don thanks is your product on amazon??
March 14, 2024 at 11:34 pm #489831electrofix
ModeratorBigdad wrote:OK Don thanks is your product on amazon??
no the site shop is not on Amazon. If they had to pay Amazon charges things would be dearer
April 1, 2024 at 12:20 pm #489832Bigdad
ParticipantHi all can anyone help me I got a problem with my servis washing machine front control board model number M6755W “front loader”
problem is everytime i press the starter button the machine starts for few seconds than stop what could be the problem??April 1, 2024 at 12:36 pm #489833Bigdad
ParticipantI have sent a photo of the back of the control PC board for my servis washing machine above
April 1, 2024 at 12:52 pm #489834Bigdad
ParticipantDon do you stock servis washing machine front control PC board model number M6755W front loader at Whitegoods.com??
April 1, 2024 at 1:59 pm #489835electrofix
Moderatordoubt you can still getb the board due to age
there will prob be 2 board in the machineyou could ask
https://www.qualityelectronicrepairs.co.uk/
to see if they can repair
April 2, 2024 at 6:14 am #489836andyjawa
ParticipantBigdad. Questions to you: so presumably you changed the door interlock and that hasn`t cured your problem, yes or no? Does the door now lock, yes or no. You have then gone over to the instrument panel`s pcb, question: why? Is the start micro switch broken, sheard off for example, have you physically visually looked at the start button`s micro switch? If everything is still intact that could well be just as well since looking even on foreign sites that part appears to be obsolete. If that pcb is damaged your only hope is a s/hand board off ebay or a repair if possible to that pcb.That pcb is a version 2 pcb.
Your best bet considering the age of the machine is to check the motor brushes since from memory “starting stuff” is wired through the motor. Could be wrong, not unknown(!), but by now I would of thought they would be on their last legs and if worn out that should be your answer.
As far as the main pcb goes tread carefully. Some of these Servis pcb had to be pre programmed so it wasn`t the case of buying one swopping the wires to the new pcb and expect it work. I think you can still get that pcb if all else fails. If you see the word “Janus” anywhere the main pcb has to be preprogrammed from memory. On the inside of your filter flap there was a long number in heavier print and if so that was the coding for a new pcb.
Just to make the point to you there were Servis made in uk, they went bust, then there were Servis where that name was bought and used in the manufacturing by Merloni in Italy (your machine) then they went bust, then to present modern times Servis name used by Vestel of Turkey that usually have round filter flaps. None of these were the same machines, all were/are completely different contraptions. -
